Bug in time filter
Hello there,
I need to display on the same row different panels with different time ranges, therefore I edited the query to ignore the time range of the panel.
However this does not seem to work, see example from screenshot below.
The top time range is set from 1 December but the time condition on the manual query is from the 19 December.
The chart is still using the time range from the panel to select the X-axis.
My goal is to have N panels with non overlapping time slots as sequential panels.
Is there a way to override the X-axis time range?
