Not able to override time by setting an absolute time range
I’m aware that it is possible to customize time settings for graph panel by setting the ‘Override relative time’ field in ‘Time Range’. However, I can’t set absolute fixed time range that is static and different than the time represented by other panels in the same dashboard. Any work around for this issue? Thanks!
no there is currently no way to do that :frowning:
Alright. It would be great to have it though!
Thanks for the reply. (y)
Is this still true? No way to set an absolute range? :frowning:
