I have a dashboard with multiple Time Series panels that need to display different time ranges. I am aware of setting different relative times using the query options, but I need these time ranges to be absolute and specified from variables.
Is this possible?
The only way I think you could do it is in the queries ising time offsets to virtually have everything in the same “time range” or using a similar approach but using the xy plugin to have an scatter graph and use something other than time as X (maybe an index number?)
