v8.2.7 and any version of 8.3 enterprise docker -
upgrade from v8.2.7 to v8.3.4, since 8.2.7 has bugs in regex value mapping -
Upgrade to new version, reload the container and UI, and view my dashboards -
What happened?
Most of my dashboards are blank. I have to click into each individual widget and re-add the datasource. The odd part is, the datasource appears in the selection box already predefined, but I STILL have to manually click it, and re-select it even though it is currently selected -
My dashboards to be there. -
yes -
No errors -
Export and import | Grafana Labs
and
Dashboard HTTP API | Grafana Labs
Hi @nxhatfield, welcome to the community!
Thanks for bringing this up. I looked into this issue and found that you’re already working with Torkel on this issue in github:
I wanted to mention it here for other community users that could encounter the same thing.
