Broken expression using queries from multiple datasources
After updating Grafana, one of my panels is now showing an error: “All queries must use the same datasource”.
It used to work but not anymore.
It’s a simple expression which is the sum of 4 queries using 3 different datasources (all Prometheus DS).
The queries work but when I add the expression and hide the queries, I get the error message.
How can I do maths on my queries if they are using different DS (which was working perfectly until a recent update)?
Thanks,
JC
    8.2.1
    Expression/calculation based on multiple datasources
    Multiple hidden queries, expression using $A + $B + $C + $D
  • What happened?
    It was working until last update, now showing “All queries must use the same datasource”
    My expression to show the result = sum of 4 queries
    There are 4 queries using count(system_uptime{}), and then I sum all results into one expression.
    Exclamation mark message on the top-left corner of the panel: All queries must use the same .datasource
    n/a
I am having same issue
Me too, after updating to v8.2.2
It will be fixed in next v8.2.3
