I am using Grafana 9.4.7 Enterprise version. Boom theme has suddenly stopped working and when I checked the plugin info, a pop-up is displaying that says ‘The Boom Theme plugin has been deprecated and is no longer maintained.’
I have been using the plugin and client liked it, now it stopped working. Please help.
Thanks
Hi @mittamanjusha if you upgraded your grafana instance is likely whatever method the plugin was using to inject the theme is not longer working and the plugin author won’t push updates to fix it.
The plugin page specific this plugin is deprecated so it is unlikely you will find a fix for it unless you decide to modify the source code and make it work yourself.
