Boom Theme Image Background
Hi. I am trying to set an image as a background in the grafana dashboard but it doesn’t work.
I stored the image inside C:\Program Files\GrafanaLabs\grafana\data\plugins\img folder. Putting the image inside the boom theme folder will gives me an error. Does anyone knows how to do it correctly?
Thank you.
Hi @diazstephanie
Thanks for providing details with screenshot.
Just wanted to be sure if you had already looked at :
Boom Theme plugin for Grafana | Grafana Labs ?
You can install apache http on you grafana server that uses port 80 or 443 (if https) then place your image in /var/www/html.
Then your url would be http(s)://{your grafana domain name}:80/{your image name}
