Best way to show values X pixels to the right of the stacked bars, rather than on top of them?
    Grafana Cloud ON Mac OS
    I want to show bar values X pixels to the right of the stacked bar, rather than on top of it.
    I know this isn’t possible with the regular stacked bar functionality and was wondering if the best way to do this was via a custom plugin, or somehow editing the JSON of the dashboard?
      "datasource": {
        "type": "grafana-postgresql-datasource",
        "uid": "ceffjw790d24gc"
      "fieldConfig": {
        "defaults": {
          "color": {
            "mode": "thresholds"
          "custom": {
            "axisBorderShow": false,
            "axisCenteredZero": false,
            "axisColorMode": "text",
            "axisLabel": "",
            "axisPlacement": "auto",
            "fillOpacity": 80,
            "gradientMode": "none",
            "hideFrom": {
              "legend": false,
              "tooltip": false,
              "viz": false
            "lineWidth": 1,
            "scaleDistribution": {
              "type": "linear"
            "thresholdsStyle": {
              "mode": "off"
          "mappings": [],
          "thresholds": {
            "mode": "absolute",
            "steps": [
                "color": "dark-red"
        "overrides": [
            "matcher": {
              "id": "byName",
              "options": "NBA Volume"
            "properties": [
                "id": "custom.axisColorMode",
                "value": "text"
                "id": "color",
                "value": {
                  "mode": "palette-classic"
            "matcher": {
              "id": "byName",
              "options": "College Basketball Volume"
            "properties": [
                "id": "color",
                "value": {
            "matcher": {
              "id": "byName",
              "options": "MLB Volume"
            "properties": [
                "id": "color",
                "value": {
            "matcher": {
              "id": "byName",
              "options": "NHL Volume"
            "properties": [
                "id": "color",
                "value": {
            "matcher": {
              "id": "byName",
              "options": "__total_volume"
            "properties": [
                "id": "custom.hideFrom",
                "value": {
                  "legend": false,
                  "tooltip": false,
                  "viz": true
            "matcher": {
              "id": "byName",
              "options": ""
            "properties": []
      "gridPos": {
        "h": 18,
        "w": 12,
        "x": 12,
        "y": 0
      "id": 10,
      "options": {
        "barRadius": 0,
        "barWidth": 0.97,
        "fullHighlight": false,
        "groupWidth": 0.7,
        "legend": {
          "calcs": [],
          "displayMode": "list",
          "placement": "right",
          "showLegend": true
        "orientation": "auto",
        "showValue": "always",
        "stacking": "normal",
        "tooltip": {
          "hideZeros": false,
          "mode": "single",
          "sort": "none"
        "xTickLabelRotation": 0,
        "xTickLabelSpacing": 0
      "pluginVersion": "11.6.0-84846",
      "targets": [
          "editorMode": "code",
          "format": "time_series",
          "rawQuery": true,
          "rawSql": "WITH date_series AS (\r\n    SELECT generate_series(\r\n        GREATEST(\r\n            (SELECT MIN(DATE_TRUNC('day', settled_at)) FROM reporting_trades),\r\n            to_timestamp($__from/1000)\r\n        ),\r\n        LEAST(CURRENT_DATE + 1, to_timestamp($__to/1000)),  -- Added +1 to include current partial day\r\n        '1 day'::interval\r\n    )::date AS day\r\n),\r\nsettled_leagues AS (\r\n    SELECT\r\n        t.*,\r\n        e.start_date,\r\n        e.tournament_name,\r\n        DATE_TRUNC('day', t.settled_at) AS settled_day\r\n    FROM trades t\r\n    JOIN events e ON t.event_id::VARCHAR = e.event_id\r\n    WHERE t.settled_at IS NOT NULL\r\n      AND t.settled_at >= to_timestamp($__from/1000)\r\n      AND t.settled_at < to_timestamp($__to/1000)\r\n      AND e.tournament_name IN ('NBA', 'College Basketball', 'MLB', 'NHL')\r\n)\r\nSELECT\r\n    ds.day::timestamp AS time,\r\n    -- TO_CHAR(day, 'MM/DD') || ' (g=' || __total_volume || ')' as date_and_games,\r\n    COALESCE(SUM(CASE WHEN sl.tournament_name = 'NBA' THEN sl.stake ELSE 0 END) / 1000.0, 0) AS \"NBA Volume\",\r\n    COALESCE(SUM(CASE WHEN sl.tournament_name = 'College Basketball' THEN sl.stake ELSE 0 END) / 1000.0, 0) AS \"College Basketball Volume\",\r\n    COALESCE(SUM(CASE WHEN sl.tournament_name = 'MLB' THEN sl.stake ELSE 0 END) / 1000.0, 0) AS \"MLB Volume\",\r\n    COALESCE(SUM(CASE WHEN sl.tournament_name = 'NHL' THEN sl.stake ELSE 0 END) / 1000.0, 0) AS \"NHL Volume\",\r\n    COALESCE(SUM(sl.stake) / 1000.0, 0) AS \"__total_volume\"\r\nFROM\r\n    date_series ds\r\nLEFT JOIN\r\n    settled_leagues sl ON ds.day = DATE_TRUNC('day', sl.settled_day)\r\nGROUP BY\r\n    ds.day\r\nORDER BY\r\n    ds.day;",
          "refId": "A",
          "sql": {
            "columns": [
                "parameters": [],
                "type": "function"
            "groupBy": [
                "property": {
                  "type": "string"
                "type": "groupBy"
            "limit": 50
      "title": "Daily Stacked Volume",
      "type": "barchart"
welcome to forum @finneganlsmith
can you share a screen shot of such a bar chart?
here are some example that might help
Thanks for your reply. Here is the chart.
I took a look at the examples.
The stacked bar chart examples are close to what I’m trying to achieve.
In the examples, the values are shown inside the stacked bars. I’m trying to devise a way to ensure that it shows the numbers beside the stacked bars, so that if the stacked bar is very small, it doesn’t obscure the number.
so if it is besides it would spill into adjacent bar, but wouldn’t that create another issue?
I take your point. I guess I could make the bars narrower, to afford more space between them, but I see your point.
Yes I’m familiar with the width, thanks.
I’m still trying to find a way to show the numbers beside the stacked bars
