Hi Grafana community ![]()
I’m building an App Plugin (incident-first reliability / RCA style workflow) that correlates metrics, logs, traces, and Kubernetes context into a guided investigation view.
The plugin includes:
A backend (Go) that aggregates data and builds incident timelines
A frontend app UI inside Grafana
A TestData-based “chaos / simulation mode” for safe testing (deterministic, synthetic, real-time streams via SSE)
Clear labeling of test vs prod mode (no real telemetry is queried in test mode)
My current challenge
I’m not able to test against real production telemetry, which means:
I rely on Grafana TestData and synthetic events for most testing
Some incident lists / lifecycle flows are generated or simulated
End-to-end behavior is realistic, but the data source is not live production Prometheus/Loki/Tempo
I’ve followed Grafana plugin docs and TestData guidance, but I want to confirm best practices from experienced plugin authors.
My questions
Is it acceptable to publish a plugin for review when:
Testing is done using Grafana TestData / synthetic sources
Production datasources are supported but not exercised with real prod traffic yet?
Are reviewers generally okay with:
Deterministic synthetic incidents
Explicit “test/simulation mode” clearly labeled in the UI and docs?
Is there a recommended staging or non-prod testing pattern for app plugins that require complex observability data, before catalog publication?
I want to make sure I’m aligning with Grafana’s expectations and not over-engineering pre-publish testing.
Any guidance from Grafana team members or plugin authors would be hugely appreciated ![]()
Thanks!
