Hello Grafana community,
I’m working on a motor control calibration system and need help with visualizing experiment comparisons. Looking for best practices or plugin recommendations.
My Setup:
Grafana (v10.2.2) with InfluxDB v2.7.12 (Flux)
Data: Position measurements from motor calibration runs
Each “experiment” is a self-contained test run stored with tags:
exp_id
,direction
(forward/reverse),speed_pct
Each experiment has a
rel_ms
field (relative time from experiment start, always starts at 0)
The Challenge:
I need to overlay 2-4 experiments on the same graph, time-aligned so they all appear to start at t=0, or the start time of the earliest one in the selected set, making it easy to compare deviation patterns between forward/reverse runs or different speeds.
Current Data Structure:
Measurement: motor_position
Tags: exp_id, direction, speed_pct, host
Fields: deviation, mot_pos, enc_pos, rel_ms
Timestamp: actual clock time when recorded
What I’ve Tried:
Using
rel_ms
as time axis - Can’t figure out how to make Grafana treat a field as time for visualization -
Dynamic timeShift() - Attempted to calculate time differences between experiment start times and shift dynamically, but Flux doesn’t seem to support this easily:
flux
// Doesn't work as expected
ref_start = from(bucket: "motor-data") |> first() |> findColumn(...)
time_diff = int(v: ref_start[0]) - int(v: exp_start[0])
|> timeShift(duration: duration(v: time_diff))
- Manual time shift - Works but requires calculating offsets manually for each experiment
Questions:
Is there a Grafana-native way to align multiple time-series by a relative time field rather than absolute timestamps?
Can transformations help here? (Prepare time series, custom calculations?)
Are there plugins designed for experiment/test comparison use cases?
Should I be using a different visualization type (XY, scatter, etc.) instead of time series?
Is this better solved outside Grafana (preprocessing, different tool)?
Ideal Workflow:
Browser panel showing available experiments
Multi-select dropdown to pick 2-4 experiments (or click to pick in the table of experiments)
Main graph shows them overlaid, all starting at relative time 0
Forward runs in one color, reverse in another
Experiment Structure:
Sample rate: 20Hz (50ms intervals)
Typical experiment duration: 2-60 seconds
Any guidance on best practices for this type of experiment-based analysis in Grafana would be greatly appreciated!
Thanks in advance!
|\\/|ark.
