Hello there,
I’ve a question what’s the expected behavior and how I might solve my issue.
Background:
I’ve got a Dashboard to display disk metrics that is used by different system. The dashboard loops by row over a template variable that can contain 1 to thousands of objects. Multi-value and “select all option” is selected for the template variable.
The idea is to provide a list of objects, where each user can select the objects he want to compare and save as dashboard.
Problem
If I provide such a dashboard with a preselection, this objects might be not found on the users side. In this case the variable will fallback to All which results in a loop over all objects and crash the Browser in many cases.
Question
- Is this the expected behavior?
- Is there a solution to fallback to display nothing instead of all objects?
Best regards
Dirk
