I would want to display a line graph and a bar graph in a single graph panel through a single or multiple metric query. Is this possible(in time mode)? If yes will it be possible in series mode as well?
Thanks in advance
Alan
Thanks in advance
Alan
Yes it is possible, you can have both enabled at the same time.
And you can use series overrides to specify it per series
Thank you Torkel.
Got it.
@torkel, I could achieve this in the time mode but I would like to be clarified if the same would be possible in series mode?
hi ,Did you got answer for this?
