Hey All,
I’m using Grafana V8.0.5 and I’m trying to use the bar chart panel as a way to filter the dashboard.
My bar chart display different teams and I want to link each bar to the the dashboard with the updated URL of the specific Team.
Working with the stat panel I was able to create a similar outcome but with the bar chart I can’t seem to find a way to link the actual graph and not just the panel.
Is anyone managed to do it? or have another solution that will allow the user to filter using visualization?
Thank for the help,
