- 12.1.1 Community Edition
Consider these two horizontal bar charts attached …
the data will be dynamically generated from an API call
sometimes we get 2 “rows” , sometimes we get 50 rows …
from what I have seen from Grafana, it is asking me to put the bar-chart inside a panel,
and I have to give this panel a fixed width-and-height (as part of “dashboard design phase”)
this will result in weird looking bar charts … the bars can easily become too thin or too wide
two solutions could have solved this problem :
auto resizing panels (it knows how many rows/bars are to be visualized)
fixed width bars (and I just place the bar-chart inside a very big panel as the last row of the dashboard)
neither of the two above appear to exist in Grafana ? (I wish to be wrong on this)
the bar-chart is auto-resizing relative to the parent panel,
- but the panel is not auto-resizing relative to the parent dashboard !!!
- I looked at the config options and searched google and youtube, no luck.
What happened?
- I am seeing horizontal bar charts that can have bars that are either too thin or too wide
- Looking for a way to have fixed width horizontal bars
- there is no configuration, i am using defaults
- no errors encountered
- I am unable to find instructions to set horizontal bar charts to fixed width
