I’m getting following error:
Azure Monitor: Unauthorized: AuthenticationFailedMissingToken. Authentication failed. The ‘Authorization’ header is missing the access token.
I’ve generated the api key and passed it as a header as follows:
Authorization: Bearer
but the error still appears.
The azure monitor data source is deployed via curl and when I check for it with /api/datasources, I can see that all fields for client secret, tenant id, client id are populated.
The only thing that works is that when I manually paste the client secret to the corresponding field. The error then disappears and it works even without using generated api key.
Anyone has a clue what may be wrong here?
thanks
