I deployed Grafana using Helm and wanted to set up Azure Monitor as a data source. I followed the documentation on how to add this data source: Azure Monitor data source | Grafana documentation. I added the necessary YAML configuration to my Helm chart, and Azure Monitor appears in the connections section.
However, even though I have already configured the client secret, Grafana is still asking for it. Additionally, the client ID and tenant ID fields are not being populated.
Yaml file which I have used :
apiVersion: 1 # config file version
datasources:
- name: Azure Monitor
type: grafana-azure-monitor-datasource
access: proxy
jsonData:
azureAuthType: clientsecret
cloudName: azuremonitor # See table below
tenantId:
clientId:
subscriptionId: # Optional, default subscription
secureJsonData:
clientSecret:
version: 1
Second one :
datasources:
datasources.yaml:
apiVersion: 1
datasources:
access: proxy
isDefault: true
jsonData:
azureAuthType: clientSecret
clientId: xxxx
subscriptionId: xxxx
tenantId: xxxx
secureJsonData:
clientSecret: xxxx
