Hi all,
I am using aws managed grafana and my queries are timing out at 60s.
Snowflake data source.
How can I change this setting? I know it is not a Snowflake setting.
Thank you
Hi all,
Thank you
Snowflake datasource has a config, where you can customise timeouts for your needs:
If you can’t change them, then contact your AWS support - it is AMG, so some options can be restricted/modified by the provider (AWS in this case).
Thank you!
