Hello, having issues with CloudWatch datasource, so i created a panel with the cloudwatch source, i have something working very basic for memory monitoring from the cloudwatch ‘Agent’.
I am trying to create panel with multiple instances showing on one panel for example 10 instances with their cpuutilisation so i should see 10 instances of legend values one per instance recording its cpu utilisation, so i created a variable which shows 5 available instances and it still only shows one metri.
What could be going wrong?
Is this even possible?
I have attached what i have so far, the instances variable has 5 instances inside, it is only picking up the first instance it sees ![]()
