AWS Cloudwatch using ARN in Grafana inside Kubernetes with uswitch/kiam
Hello there, I deployed Grafana inside our k8s cluster with kind statefulset ,
here I need to add cloudwatch plugins using ARN as Auth Provider, using https://github.com/uswitch/kiam to communicate all our service with AWS IAM,
I already deep dive in Grafana AWS Cloudwatch Official Docs and https://github.com/uswitch/kiam/blob/master/docs/IAM.md,
and searching in grafana community here,
but no luck,
I already attached this to Trust Relationship in my grafana role too :
  "Version": "2012-10-17",
  "Statement": [
      "Sid": "",
      "Effect": "Allow",
      "Principal": {
        "Service": "ec2.amazonaws.com"
      "Action": "sts:AssumeRole"
      "Sid": "",
      "Effect": "Allow",
      "Principal": {
        "AWS": "arn:aws:iam::123456789012:role/kiam-server"
any one can help me to accomplished this?
noticable log :
in kiam-server
{"credentials.access.key":"XXXXXXXXXXXXXXX","credentials.expiration":"2019-12-16T06:24:19Z","credentials.role":"arn:aws:iam::XXXXXXXXXXXXXXX:role/grafana-dev-iam-role","generation.metadata":0,"level":"info","msg":"fetched credentials","pod.iam.role":"arn:aws:iam::XXXXXXXXXXXXXXX:role/grafana-dev-iam-role","pod.name":"grafana-0","pod.namespace":"istio-system","pod.status.ip":"","pod.status.phase":"Pending","resource.version":"45664633","time":"2019-12-16T06:06:05Z"}
in grafana pods :
t=2019-12-16T06:15:47+0000 lvl=eror msg="Metric request error" logger=context userId=1 orgId=1 uname=admin error="Failed to call ec2:getAwsConfig, AccessDenied: User: arn:aws:sts::XXXXXXXXXXXXXXX:assumed-role/grafana-dev-iam-role/kiam-kiam is not authorized to perform: sts:AssumeRole on resource: arn:aws:iam::XXXXXXXXXXXXXXX:role/grafana-dev-iam-role\n\tstatus code: 403, request id: 7ff33a3a-1fcb-11ea-b0f2-d3fa2c1d9a6b"
#aws #kiam
It it not clear how did you configure all roles and why you need all of them: role/grafana-justice-dev-iam-role, role/grafana-dev-iam-role.
Had the same issue and I’m still investigating, maybe it is related to this open issue - https://github.com/grafana/grafana/issues/20473
However I have found a strage fix - you need to change credentials type from “arn” to “credentials” (Credentials file) leaving the path to the file empty (default)
After that change - everything works as expected.
Hope that helps,
Roman
Wow thank you so much for the hint! I will propose this to be added to the Grafana docs
Hi! Actually this fix is not required anymore, linked github issue is solved and all works as expected with assumeRoleArn and authtype: arn in grafana 7.1.1+
