9.0.6 -
replace all panels with title with library panel -
attempting to download with api use jq to find panels with title and replace with library panel - What happened?
error with jq - What did you expect to happen?
replace the panel with librarypanel version - Can you copy/paste the configuration(s) that you are having problems with?
cat ./original_dashboards/some_dashboard.json | jq ‘. | ..dashboard.panels? | select(.title == “Process CPU Usage”) = $CONTENT_FROM_FILE’
jq: 1 compile error
Open to any other possible method, but have around 300 dashboards to link to librarypanel instead of using standalone
