Is it possible to make dashboard preset
    Grafana v10.1.1 (0cfa76b22d)
    I want to create a “parent” dashboard with some variables. Then I want to clone it (so, create many child dashboards) with particular variables values. But, I need to have an ability to change all child dashboards just by changing the only parent dashboard
Hi @rayskiyvladimirr ,
Library panels can help you achieve that. Take a look at:
Best regards,
ldrascic
