Auto Update Panel During The Creation Process
I’m trying to have the panel auto-update during the configuration process of the panel. For example, when I change the title, the panel should auto-update instead of my having to run a query or click the panel.
I found that I could run a query or I could click the panel and it would update the panel’s title.
  • What happened?
I expected that the panel title would be auto-updated like any other configuration that I change.
Screenshot 2023-09-03 at 12.20.59 AM
N/A
Yes, I was learning how to create a dashboard by following:
