Authentication issues behind reverse proxy
    11.1.5 in Kubernetes
    We enabled jwt authentication and the auth flow works.
    In our case an API gateway injects the authentication token in the header. Now we face the issue that the user login works but, in the developer tools we can see that the websocket authentication does not work.
Error message:
WebSocket connection to ‘wss:///api/live/ws’ failed: HTTP Authentication failed; no valid credentials available
We enabled it through grafana.ini and grafana ini looks like this:
[analytics]
check_for_updates = true
[auth]
anonymous = false
disable_login_form = true
disable_signout_menu = true
login_maximum_inactive_lifetime_duration = 30s
login_maximum_lifetime_duration = 1s
oauth_auto_login = false
[auth.anonymous]
enabled = false
[auth.jwt]
auto_sign_up = true
enabled = true
header_name = Authorization
jwk_set_url = “…”
role_attribute_path = “…”
[grafana_net]
url = https://grafana.net
[log]
mode = console
[paths]
data = /var/lib/grafana/
logs = /var/log/grafana
plugins = /var/lib/grafana/plugins
provisioning = /etc/grafana/provisioning
[security]
allow_embedding = true
[server]
domain = ‘’
  • What happened?
    We face an error with the websocket connection:
    Error message:
The dashboards to not update, be we can get the latest values by reloading the page.
    It just works.
    I did not find any logs, but I got the error in the frontend dev tools.
    Yes, Grafana JWT documentation
That “API gateway” must have proper support for websockets. Are you really sure that’s supported in your case? Not all proxies can transparently proxy WebSocket connections by default.
@jangaraj Sorry to revive old thread. But I noticed a similar behaviour when using the d-solo endpoint using a headless chromium. What I was trying to do is to render a panel using Authorization header in the request to headless chromium. All the requests to the Grafana assets use the header except the requests where connection is upgraded to websockets. So, in the websockets handshakes, Grafana is not forwarding the auth header and hence, panels do not render.
Is it a bug or intended behaviour from Grafana?
Cheers!
