Grafana 9.3.2 on Ubuntu 18.04.4 LTS
- What are you trying to achieve? | What happened?
I would like to configure AWS Athena as a Data Source using the IAM credentials of the machine Grafana is running on. I am not using AWS Managed Grafana.
- How are you trying to achieve it?
I expected the data source to save without error.
- Can you copy/paste the configuration(s) that you are having problems with?
Image of AWS data source configuration above. AWS IAM role for the machine running grafana is setup to use Amazon’s AmazonGrafanaAthenaAccess policy which includes the following relevant permission:
"Effect": "Allow",
"Action": [
"athena:GetQueryExecution",
"athena:GetQueryResults",
"athena:GetWorkGroup",
"athena:StartQueryExecution",
"athena:StopQueryExecution"
"Resource": [
"Condition": {
"Null": {
"aws:ResourceTag/GrafanaDataSource": "false"
The ec2 instance which grafana is running on is configured to use this IAM role and contains the tag GrafanaDataSource: true
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
See above image.
