Grafana Native S3 Integration through AWS IAM Role
    Using Grafana Cloud v9.5.7 do not have available details around OS usage, assume a entreprise version of Linux.
    Retrieve and render S3 stored data using AWS IAM Role authentication scheme.
    To our knowledge Grafana does not natively support this feature, it does not allow to retrieve a JSON or CSV file stored in a S3 Bucket and use that content to render some dashboard panels. The team established a PoC with the usage of a open source plugin yesoreyeram-infinity-datasource which does include an AWS integration method through long-term IAM User credentials. As a side note this is a temporary measure seeing this is expected to migrate to our primary data source SnowFlake by EoY.
  • What happened?
    Once moving the PoC to our live environments, a security concern was raised around the AWS authentication method utilized in said plugin prompting a challenge to instead utilize a more organizational streamline AWS authentication method, through a specific IAM Role.
    To prepare the PoC the team has based their development from the following article AWS API | Grafana Plugins documentation
Try dofferent approach - Athena
You may also try to access s3 data via http (and have IAM in a place, e. g. s3 bucket policy which allow only Grafana role to have access)
Indeed Athena is a perfectly viable option, if not for this solution representing a temporary measure…
The idea would be at the earliest convinience to migrate this data source to a more structured and flexible design, in our case SnowFlake which already includes a wide variety of our organizational tenants allowing us to support a wider range of use cases.
It seemed counter productive to create our team’s exclusive and robust data lake solution using something like AWS Glue/Athena to then be scrapped in favor of another tool more inline with organizational pratices.
The idea to consume it through HTTP does intrigues me, seing it as a possible low hanging fruit although again from what I’ve gathered Grafana also does not support this natively and requires again the yesoreyeram-infinity-datasource plugin. Would need to verify if in Grafana Cloud being a SaaS platform allows us to provide and set its own IAM Role, I’m aware if utilizing a native datasource (e.g. CloudWatch or Athena) there would be seemless akthough with this open source plugin would not sure TBH our bullet-proof alternative would be to expose a MS to retrieve this data and provide it through HTTP to grafana via this plugin has its datasource, although I can already foresee some waves or a bombardment of questions around data exposure even if we were to assure encryption on travel and propper authorization in place.
:person_shrugging: :person_shrugging: :person_shrugging:
So answer, which you don’t want to hear: there is no native way.
Go and request native S3 datasource: Data Source Roadmap · GitHub (I would like to see how unstructured data from S3 can be visualized :-D)
I admit… Indeed that is not the answer I would want to hear although it is pretty much the one I would expect.
No real concerns, we were simply challenging the need to create a AWS IAM User to accomudate this plugin’s AWS authentication UX (which requires long-term credential configuration) and to instead rely on a much more manageable IAM Role… Then again this being a temporary measure I suppose some form of compromise is to be expected.
Appreciate your commentary on the topic @jangaraj :slight_smile:
You might want to check if recent Grafana versions or updates provide native support for S3 data integration via IAM roles. If not, using a dedicated plugin or the forbidden leggings considering alternative approaches for secure AWS authentication might be necessary.
