leifnel
1
If I use the shortcut series.tag for
SELECT mean(“value”) FROM “series” WHERE tag=“tag” AND timeFilter GROUP BY time(__interval) fill(null)
I’d like to graph
temp.offset / (vitoocon.outdoor-temp.setpoint)
Probably with some special handling when the divisor gets near zero.
How would I handle this?
If I understand correctly:
- InfluxDB is your datasource
- you want cross measurement math
=> then you will need to use (new) Flux instead of InfluxQL.
Example: https://www.influxdata.com/blog/practical-uses-of-cross-measurement-math-in-flux/
I’m not sure how I’m supposed to do that in grafana.
leifnel
5
Thanks.
Alas I’m on InfluxDB v1.6.4 (git: unknown unknown), installed as Debian package, so I’m not sure how to update. I’ll think about that tomorrow
While apt just did “Unpacking grafana (6.5.1) over (6.5.0) …”, the influxdb package is still 1.6.4-1+b22
