applyFieldOverrides with custom.width
I’m creating a plugin that involves using the @grafana/ui Table component. Right now I’m facing the issue that when I’m calling applyFieldOverrides with a custom.width property it doesn’t end up getting reflected in the DataFrame.
I can get overrides to work where the property.id is on the FieldConfigProperty. However when I try to use an override like this, it doesn’t end up in the DataFrame.fields.config.custom.width.
      matcher: {
        options: fieldDisplayName,
      properties: [
          value: width,
I face the same issue with using custom.hidden and simply had to go modify the DataFrame manually after calling applyFieldOverrides but this feels so janky and I’m manually rewriting what applyFieldOverrides is supposed to be doing.
These seem to work fine when applying overrides to Grafana’s native TablePanel. This is obviously only a portion of the implementation but I’m getting the fieldDisplayName and width from the Table’s onColumnResize. Very similar to https://github.com/grafana/grafana/blob/main/public/app/plugins/panel/table/TablePanel.tsx#L86
const overrides = [{
      matcher: {
      properties: [
          value: width,
let overriddenData = applyFieldOverrides({
      data: [modifiedFrame],
      fieldConfig: {
        overrides,
        defaults: {},
      theme,
      replaceVariables: (value: string, scopedVars?: ScopedVars) => {
        return getTemplateSrv().replace(value, scopedVars);
    })[0];
// at this point I would expect the field to have config.custom.width to be set but it isn't
After pouring through source code I finally found that the custom.width is allowed as an override property because of the useFieldConfig and useCustomConfig in the plugin definition. This automatically prepends the registry id with custom for the path which makes adds it to the fieldConfigRegistry in the overrides.
This would probably be worth mentioning in the @grafana/ui documentation.
