I have verified that I can ship metrics when running k6 cloud locally.
Hey @leathej1,
We’re investigating the issue.
Update:
The issue is fixed and the DataDog integration in Cloud APM works properly now.
No, I am still not seeing it.
Oh, that functionality is still in the works, I guess. Hmm… that means I have to change depending on whether I run my script locally or in cloud. Can’t we just continue to ignore it if not applicable?
I have removed name and the metrics are still not being pushed.
I have tested your same exact APM config with our api- and appKey with an script on the cloud and it works perfectly.
I have also recreated the project, using the same script that I ran locally. The local execution is successfully sending data while the cloud execution is still not.
If you’re using __ENV variables directly on Cloud via Script Editor, they might not be replaced with their values.
I found the issue that causes your test run not to export metrics, and I am releasing a hotfix today.
Update:
The hotfix is released. Please test again.
k6 Cloud:
DataDog:
Azure Monitor:
