For example:
var response = http.get(`http://${tenant}`, {
tags: { name: `${stepNum} - http://${tenant})` },
These names make it fine to k6 cloud,
but not through the Datadog connector.
For example:
export let options = {
// Connection and metrics information for running on k6 cloud
ext: {
loadimpact: {
projectID: projectID,
name: "SSO login flow",
apm: [
provider: "datadog",
apiKey: "apiKey",
appKey: "appKey",
metrics: ["http_reqs", "http_req_blocked", "http_req_connecting", "http_req_tls_handshaking", "http_req_sending", "http_req_waiting", "http_req_receiving", "http_req_duration"],
includeDefaultMetrics: true,
includeTestRunId: true
The name
metric should be included by default, no? Tags and Groups
Hi @leathej1 ,
I now noticed that you are actually using the k6 cloud integration with datadog.
I have moved this to the correct SaaS forum and am now pinging @mostafa who should be able to help you
Oh, sorry about that. Thanks.
Hey @leathej1,
The more granular you want to be able to filter your metrics on DataDog, the more records DataDog needs to create on their database, which is achieved by sending tags along with custom metrics (k6.*
) to their platform.
AFAIk, we omitted sending tags (hence includeTestRunId: false
by default) because tags incur a hefty cost.
So what is the workaround in this case? Do I have to create a trend for every metric/url? Or can I force sending the name tag…?
Creating a custom metric and adding it to metrics
key would help, for now. You can’t force sending the name
tag.
Really? Because I just added this:
metrics: ["name",
and now it works.
Ohh… that only works from k6, not k6 cloud. Ugh.
