I am using the awesome Volkov Labs plugin to create some better charts for my business data.
I am currently trying to sync the datazoom on one panel to another. Is this possible? I am trying to bypass the native date selector as I want to avoid triggering a query.
The thought was spurred by the idea of blending components from the following tutorials:
Update time range: Event Handling | Volkov Labs
and
Syncing Crosshairs: Panels interconnectivity in Grafana via EventBus | Volkov Labs
I have been able to log the specific value I need.
From the console:
dataZoom updated!
{type: ‘datazoom’, from: ‘viewComponent_6189’, dataZoomId: ‘\x00series\x000\x000’, animation: null, start: 33.33333333333335, …}
animation: null
dataZoomId: “\u0000series\u00000\u00000”
end: 100
type: “datazoom”
but I can’t get the other panel to adjust accordingly when subscribing to the event.
I know I am leaving a lot out but I am a little out of my depth here. If I am able to log this in the console should I be able to influence the other panel?
