I have tried using Blend-Stat as value mapping works on there however I just can’t get the same results.
Anyone got Value Mapping on Stat working or found an alternative route?
Thanks
Thanks
Hi Matt I am,
I think the problem is due to the “fields” that are included within the panel.
Value Mappings work if the “field” selected is All or the Field containing the name in my scenario.
However When it pulls in the name automatically there seems to be no way to manipulate it.
s
It’s rather complicated to explain so attached some screen shots so you can see ![]()
