Any plugins support "Organized Hierarchical tree" could expandable?
Hi, i wonder if there is some default plugins could do that such as below:
1
  • 1-1
    • 1-1-1
2
  • 2-1
    • 2-1-1
    • 2-1-2
  • 2-2
    • 2-21-1
    • 2-2-2
3
expandable:
1 ### 1 * 1-1 * 1-1-1
i considered use markdown to make it, but it seems not the best solution. any advices?
thanks!
Regards!
It is not the same use-case but could be a good approach > plugin
okay, i will check it out. i realize that i can use @material-ui to customize a panel for it. thanks for you help!
