I have a server that is sending me traces which are in JSON format, with an undefined number of nested nodes. So it will be something like [(t1,JSON1),(t2,JSON2),…]. The depth of the JSON nodes is variable.
I would like to construct a panel where each JSON is represented as a tree that can be navigated through (for example, when I select a node, it expands and the sub-nodes are displayed which I can drill down as well etc.). I thought the JSONExplorer API (JsonExplorer | Grafana documentation) is an class that can be used for that purpose (you provide the JSON and it displays the searchable tree) but I did not manage to do it. Has anyone done something and could provide guidance.
Many thanks - Christian
Below is a sample JSON. The nested calledComponents are making up the JSON tree:
“event”: {
“duration”: “62”,
“ComponentType”: “Frontends”,
“resource”: “Frontends|Apps|YYY Proxy xxx.com.com|URLs|AAA Test YYY [/AAA/test]”,
“param”: [{
“name”: “ATTR_Proxy Host”,
“value”: “xxx”
“name”: “ATTR_Proxy Cluster”,
“value”: “machine10”
“name”: “ATTR_Proxy Folder”,
“value”: “Videos”
“name”: “ATTR_Proxy YYY”,
“value”: “AAA Test YYY [/AAA/test]”
“name”: “ATTR_Client IP”,
“value”: “192.168.225.1”
“name”: “Request Size (bytes)”,
“value”: “0”
“name”: “Response Size (bytes)”,
“value”: “298”
“name”: “TTPlugin.correlation.proxy.1.source.host”,
“value”: “machine10dev”
“name”: “TTPlugin.correlation.proxy.1.source.ip”,
“value”: “a.b.c.d”
“name”: “TTPlugin.correlation.proxy.1.source.port”,
“value”: “8080”
“name”: “Application”,
“name”: “Proxy Host”,
“value”: “xxx.com.com”
“name”: “CorCrossProcessData”,
“value”: “00000180b8f6dc19.6abde”
“value”: “Videos”
“value”: “a.b.c.d”
“value”: “8080”
“name”: “Trace Type”,
“value”: “Normal”
“calledComponent”: [{
“duration”: “0”,
“ComponentType”: “Asserts”,
“resource”: “Asserts|in-received-rule|1|All Asserts must evaluate”,
“param”: {
“name”: “Proxy Assert Type”,
“value”: “compound”
“duration”: “0”,
“resource”: “Asserts|in-received-rule|2|Include rule Frog”,
“param”: {
“value”: “simple”
“startTime”: “1654179925373”
“duration”: “0”,
“resource”: “Asserts|in-received-rule|3|Include rule Frog”,
“param”: {
“value”: “simple”
“duration”: “0”,
“resource”: “Asserts|MTOM Global rule|1|All Asserts must evaluate”,
“param”: {
“value”: “compound”
“calledComponent”: {
“duration”: “0”,
“resource”: “Asserts|MTOM Global rule|2|Decode MTOM in”,
“param”: {
“value”: “simple”
“startTime”: “1654179925374”
“duration”: “60”,
“resource”: “Asserts|AAA Test YYY|1|All Asserts must evaluate”,
“param”: {
“value”: “compound”
“duration”: “0”,
“resource”: “Asserts|AAA Test YYY|2|Set Context Variable”,
“param”: {
“value”: “simple”
“duration”: “60”,
“resource”: “Asserts|AAA Test YYY|3|route”,
“param”: {
“value”: “backend”
“duration”: “60”,
“ComponentType”: “Backends”,
“resource”: “Backends|AAA Test YYY|route|https-//localhost-8443/hello?name=”,
“param”: [{
“name”: “ATTR_Uri”,
“value”: “http”
“name”: “Status Code”,
“value”: “200”
“duration”: “1”,
“resource”: “Asserts|in-completed-rule|1|All Asserts must evaluate”,
“param”: {
“value”: “compound”
“duration”: “0”,
“resource”: “Asserts|in-completed-rule|2|Include rule Frog”,
“param”: {
“value”: “compound”
“duration”: “0”,
“resource”: “Asserts|custom-in-completed|2.1|All Asserts must evaluate”,
“param”: {
“value”: “simple”
“startTime”: “1654179925434”
“duration”: “1”,
“resource”: “Asserts|in-completed-rule|3|Include rule Frog”,
“param”: {
“value”: “compound”
“duration”: “1”,
“resource”: “Asserts|in-completed|3.1|All Asserts must evaluate”,
“param”: {
“value”: “compound”
“duration”: “1”,
“resource”: “Asserts|in-completed|3.3|At least one Assert must evaluate”,
“param”: {
“value”: “compound”
“duration”: “1”,
“resource”: “Asserts|in-completed|3.4|All Asserts must evaluate”,
“param”: {
“value”: “compound”
“duration”: “1”,
“resource”: “Asserts|in-completed|3.5|Compare Expression”,
“param”: {
“value”: “simple”
“duration”: “0”,
“resource”: “Asserts|in-completed|3.120|Continue Processing”,
“param”: {
“value”: “simple”
“startTime”: “1654179925435”
“ComponentName”: “YYY Proxy”,
Thanks for your reply. As you can see, there are nested “calledComponent”. A calledComponent can have an array of other calledComponents, which itself can have other calledComponents. The number of “calledComponents” at a given level is not always the same, as well as the depth of the JSON tree. Hence the need for having the ability to display and tree and navigate through it.
Thanks - C
Thanks a lot. I’ve been playing around a bit and I believe TreeView expects the JSON to be of fixed sized/number of nodes … In a nutshell, I have not achieved what I’m look for yet. Given that Grafana is using React in the background, I came across this GitHub - chenglou/react-treeview: Easy, light, flexible tree view made with React. which could be of value for what I want to achieve …
sorry to hear that
if push comes to shove, branch that tree view puppy and customize it.
