Ansible (AWX) notifications into Grafana (8.4)
I would like to send job failure notifications from AWX to Grafana dashboard (Grafana version 8.4). In the Grafana side, should I need to configure datasource (Postgres) or just creating a dashboard is enough ?
On the AWX side, I will provide Grafana URL, API key.
Since this is kind of a push mechanism (AWX to Grafana), I don’t see the point of creating datasource in Grafana. Please help me to clarify this. Are there any KB articles for the same ?
There is one article on this subject in Ansible site but does not have full information.
https://docs.ansible.com/ansible-tower/latest/html/userguide/notifications.html#grafana
    Grafana version 8.4
    Send Job notifications from AWX to Grafana
    In the AWX dashbaord → Administration → Notifications → Adding Grafana URL and Grafana API key.
    I am in configuring phase and I am having doubts.
    23. Notifications — Ansible Tower User Guide v3.8.6
I am kind of facing the similar scenario. Were you able to figure out the answer?
I tried to create test notification and it was failing and then I find that connectivity from AWX to Grafana was not there so port TCP 443 was recently opened.
This is what I am checking at the moment - configuring annotations.
