Graphana fault monitoring API
One of our software development team is going to deploy Grafana to monitor internal developped software. I have been asked to integrate Grafana to Ibm netcool. What are the available api available in Grafana to generate alarms/traps?
Has anyone integrated Grafana to any fault monitoring platform?
Thanks
Maupla.
You can integrate with alert notifcations using the alert notification webhook:
http://docs.grafana.org/alerting/notifications/#webhook
Were you able to do the Grafana Netcool integration? If so could you please let me know how it was done, configurations on grafana side as well as on Netcool
Hey,
Even I am looking for the same information? were you able to find any?
