Anonymous access works in v8 but doesn't in v9
    v9.5.2
    Enable unauthorized access for my dashboard
    Setting up the following fields in grafana.ini
#################################### Users ###############################
[users]
# disable user signup / registration
allow_sign_up = false
# Allow non admin users to create organizations
allow_org_create = true
[auth]
# Set to true to disable (hide) the login form, useful if you use OAuth, defaults to false
disable_login_form = true
#################################### Anonymous Auth ######################
[auth.anonymous]
# enable anonymous access
enabled = true
# specify organization name that should be used for unauthenticated users
org_name = Main Org.
# specify role for unauthenticated users
org_role = Admin
# mask the Grafana version number for unauthenticated users
hide_version = true
#################################### Basic Auth ##########################
[auth.basic]
enabled = false
  • What happened?
    When opening a dashboard I get “Unautorized” message.
    Dashboard loads.
The anonymous access works if I simply change grafana version from v9 to latest v8
@dodinroman I noticed the unauthorized message with Anonymous access enabled when I was logged in and restarted Grafana 9.5.X.
Usually, I log in and log out to clear my cookies and refresh.
omg, thanks @mikhailvolkov this was exactly it!
