Annotations Table size huge , heavy write IO to DB
Hi ,
Noticing - Huge size of Annotations Table (40G) and heavy write I/O to DB.
Got around 3k Alerts running . Added purging / rotation to bring down the capacity.
purging dropped it to 25G, i believe that will not bring down the heavy writes to DB..
i can see that , grafana alert use annotations as backend.
As there is no usecase of annotations via dashboard , is there any harm to disable this globally ? any experience. Any one attempted and how ?
Am using Grafana 10.0.1 . these are the current config.
[alerting]
max_annotation_age = 1M
[annotations]
api = map[max_age:1M]
cleanupjob_batchsize = 10000
dashboard = map[max_age:1M]
Thanks and Regards
GVK
Hi, I have like a week of annotations max age (~2.5k rules, we had problems when updating Grafana, migrations wouldn’t end), no one said anything yet (we disabled it more than half a year ago). Also with that many alerts you can check alert_rule_version table and the setting for that - I don’t remember its name but it was something like how many versions should be kept in database.
Hi @dawiddebowski ,
Thank You . that helps.
May i know how do you disable the annotations for this alerting backend.
to reduce load on the annotation table you can update alert rules to not refer to any dashboards\panels (remove annotations).
