Postgres table annotation very large
Our annotation table is very large, at 11G right now. Any idea what makes it grow so much?
grafana=> select count(*) from annotation;
  count
 34422532
Regards,
Tobias
I guess it’s alerting. Ech alert change state creates annotation (vertical green, yellow , red line in the panel).
Thanks for the reply. Some of these alerts must be set up in a very bad way then. Would it be safe to truncate the table you think?
I would say better is to configure Grafana - see max_annotation configs:
Thanks a lot for the quick help. That did indeed do the trick.
