Hello everyone
I am trying to add a data source through the Zabbix plugin, but at the moment of opening the parameters of the data source, I get the error “An unexpected error happened”
Before I wrote here, I went through forums and similar topics, but they talked about the incompatibility of the plugin and Grafana versions. According to the documentation and in Grafana itself, it says that the versions converge:
- Grafana v.10.0.0
- Zabbix plugin 4.6.1
I tried to reinstall the plugin via the web interface, manually transferred the zip archive of the plugin, installed an older version of the plugin, and also tried to register:
environment:
- GF_INSTALL_PLUGINS=https://github.com/grafana/grafana-zabbix/releases/download/v4.6.1/alexanderzobnin-zabbix-app-4.6.1.darwin_amd64.zip;alexanderzobnin-zabbix-app
but it did not help.
P.S. In my case, grafana is running through a docker container. The paths were written in volumes before me
I’ve been trying to deal with this problem for quite a long time and have reached a dead end. What can you recommend?
