Alloy extract exceptions as label from log content
I have log lines containing Java exceptions, as shown below. I want to add a label, commonexceptions , to capture frequently searched exceptions like this. In example below it is AsgardFSException… Similarly i have 15 more common exception AsgardCacheException, AsgardException, AsgardCacheFileNotFoundException etc…
I am already extracting log level, I need exception as well. Please provide some pointers on how to proceed.
2025-01-20 17:10:28.366 [264635] ERROR ArchiverHelper:40 - fail to close archive 1737393009422-partition1371.padawan
*.padawan.AsgardFSException: java.lang.Exception: File .....padawan was deleted from local cache before we copied it to Storage
at *.asgard.padawan.AsgardFSException.throwException(AsgardFSException.java:17) ~[minor-compaction-shaded.jar:?]
at *.asgard.padawan.cache.AsgardCacheLocalFSOutput.close(AsgardCacheLocalFSOutput.java:32) ~[minor-compaction-shaded.jar:?]
... 20 more
You first need to determine what string would be the same across all your exceptions, so we can parse from. I picked the string *.asgard.padawan.AsgardFSException.throwException, but i don’t know if this works for you or not.
Assuming your exception log is in one line, you can try:
loki.process "local" {
  forward_to = [<LOKI_RECEIVER>]
  stage.regex {
    expressions = `\*\.asgard\.padawan\.(?P<exception_name>[^\.]+)\.throwException`
  stage.labels {
    values = {
      exception_name = "",
Thanks Tony! this works when tried for that particular exception, but across the other exceptions it was hard to find common string. So I tried something like below based on your other thread responses and it works.
I am trying to add 15 match stages, Would this create an overhead for the Alloy agent due to the multiple match stages?
stage.regex {
  expression = "^(?s)(?P<date>\\S+) (?P<time>\\S+) (?P<thread>\\[\\d+\\]) (?P<level>\\w+)\\s*(?P<classname>\\w+:\\d*) - (?P<msg>.+)$"
stage.labels {
  values = { level = "level" }
stage.match {
  selector = "{level=\"ERROR\"}"
  stage.regex {
    expression = `^(?s)(.*Exception.*)$`
  stage.static_labels {
    values = { exception = "GenericException", }
stage.match {
  selector = "{exception=\"GenericException\"} |= \"IllegalArgumentException\""
    values = { exception = "IllegalArgumentException" }
stage.match {
  selector = "{exception=\"GenericException\"} |= \"AsgardCacheException\""
    values = { exception = "AsgardCacheException" }
stage.match {
  selector = "{exception=\"GenericException\"} |= \"AsgardException\""
    values = { exception = "AsgardException" }
No, I think generally match block is pretty efficient, and 15 is not a number I would be concerned about.
