Extract log level via regex and set it as a label
Hi there,
I used to extract my logs level through logfmt with the code below:
loki.process "add_dynamic_label" {
    stage.logfmt {
        mapping = { "extracted_level" = "level" }
    stage.labels {
        values = { "level" = "extracted_level" }
    forward_to = [loki.write.local_loki.receiver]
This works but unfortunately, somehow Alloy reports lots of logfmt errors:
msg=“failed to decode logfmt” component_path=/ component_id=loki.process.add_dynamic_label component=stage type=logfmt err=“logfmt syntax error at pos 117 on line 1: unexpected ‘=’”
msg=“failed to decode logfmt” component_path=/ component_id=loki.process.add_dynamic_label component=stage type=logfmt err=“logfmt syntax error at pos 46 on line 1: unexpected ‘"’”
After doing some researches, those errors do not appear to be fixable for the time being.
Nonetheless, I have decided to go down the regex path to extract my log levels but I am failing. Here is my config:
    stage.regex {
        expression = `(?i)\b(info|debug|error|warn|trace|fatal)\b`
    stage.labels {
        values = { "level" = "" }
Would any body know how I can extract the log level and assign it to the label “level” with Alloy?
Can you provide some examples of your logs, please?
Hi Tony,
Thank you for helping.
My logs are simply coming from Journald:
> journalctl
Oct 14 05:14:34 Lxde zeitgeist-fts[2693]: Error releasing name org.gnome.zeitgeist.SimpleIndexer: The connection is closed
Oct 14 05:14:34 Lxde zeitgeist-fts[2693]: zeitgeist-fts.vala:252: The connection is closed
Oct 14 05:14:34 Lxde org.gnome.zeitgeist.Engine[2678]: [16:14:34.416492 WARNING] zeitgeist-daemon.vala:453: The connection is closed
-- Boot 2c84a3183511457babcdbe528a957ef7 --
Oct 14 09:22:02 Lxde xrdp-sesman[1464]: [INFO ] Starting X server on display 10: /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
Oct 14 09:22:03 Lxde xrdp-sesman[1463]: [INFO ] Found X server running at /tmp/.X11-unix/X10
Oct 14 09:22:03 Lxde xrdp-sesman[1463]: [INFO ] Starting the default window manager on display 10: /etc/xrdp/startwm.sh
Oct 14 09:22:03 Lxde xrdp-chansrv[1472]: [INFO ] Socket 12: AF_UNIX connection received
Oct 14 09:22:03 Lxde dbus-daemon[1494]: [session uid=10000 pid=1491] AppArmor D-Bus mediation is enabled
Oct 14 09:22:03 Lxde xrdp-chansrv[1472]: [INFO ] sound_process_training: round trip time 100
Oct 14 09:22:03 Lxde dbus-daemon[1552]: [session uid=10000 pid=1550] AppArmor D-Bus mediation is enabled
Oct 14 09:22:03 Lxde dbus-daemon[1552]: [session uid=10000 pid=1550] Activating service name='org.gtk.vfs.Daemon' requested by ':1.2' (uid=10000 pid=1581 comm="/usr/bin/ibus-daemon --daemonize --xim " label="unconfined")
Oct 14 09:22:03 Lxde dbus-daemon[1552]: [session uid=10000 pid=1550] Successfully activated service 'org.gtk.vfs.Daemon'
Oct 14 09:22:03 Lxde dbus-daemon[1552]: [session uid=10000 pid=1550] Activating service name='org.freedesktop.portal.IBus' requested by ':1.2' (uid=10000 pid=1581 comm="/usr/bin/ibus-daemon --daemonize --xim " label="unconfined")
Oct 14 09:22:03 Lxde dbus-daemon[1552]: [session uid=10000 pid=1550] Successfully activated service 'org.freedesktop.portal.IBus'
I can clearly see now that some do not have a log level. Would it be possible to set a default label like “unknown” when there are not any identifiable level?
Cheers,
You are not doing a group capture, so when you reference level in your label stage it’s not created anywhere. You can also add a template stage to insert a default value. Try this (not tested):
stage.regex {
  expression = `(?P<level>(?i)\b(info|debug|error|warn|trace|fatal)\b)`
stage.template {
    source   = "level_cleansed"
    template = `{{ default "INFO" .level }}`
stage.labels {
  values = { "level" = "level_cleansed" }
Hi Tony,
It works. However, labels are created for both upper and lower case.
Would you know if there is a way to have everything lower case?
Cheers,
I think the best approach would probably be to change the label during processing to make everything lower case. Maybe something like this (not tested):
stage.regex {
stage.template {
    template = `{{ default "INFO" .level | ToLower }}`
stage.labels {
Hi Tony,
Thank you, it works perfectly :slight_smile:
hi @tonyswumac isn’t there a free online tool that one can use to vet out alloy? do you remember the url for it?
There is a config generator, but I don’t know if it actually verifies configuration. It does show the flow graph though, that’s somewhat useful.
also this is a very nice tool
