I’m sending pfSense logs to Alloy and trying to use regex to parse the logs and break them up into labels so I can organize the logs in Grafana. I’ve been at this for days and I’m close to the point of giving up. I’ve Googled, AI-ed, and tested the regex. Alloy starts and I get logs in Grafana, but none of my labels show up. Here’s my alloy config:
logging {
level = “info”
loki.write “default” {
endpoint {
url = “http://localhost:3100/loki/api/v1/push”
local.file_match “pfsense_logs” {
path_targets = [
path = “/var/log/pfsense.log”,
sync_period = “10s”
loki.source.file “pfsense_scrape” {
targets = local.file_match.pfsense_logs.targets
forward_to = [loki.process.pfsense_pipeline.receiver]
tail_from_end = false
loki.process “pfsense_pipeline” {
stage.regex {
expression = “^(?P\S+)\s+(?P\S+)\s+(?P.+?)(?:\[(?P\d+)\])?\s+(?P.+)$”
stage.labels {
values = {
ts = “”,
host = “”,
app = “”,
pid = “”,
stage.timestamp {
source = “ts”
format = “rfc3339”
forward_to = [loki.write.default.receiver]
Can someone please tell me what exactly I’m doing wrong here? Any help is much appreciated.
