Alerts notifications to Teams are being sent before reaching Repeat interval
I have alert notifications sent to Teams through a webhook. My understanding is that if the alert status doesn’t change (it remains in it’s alert state), then a notification will not be resent until the “Repeat interval” time. However, what is happening is that the notification is resent when it reaches the “Group interval” time. How do I make Grafana use the “Repeat interval”?
The following is my notification policy. I am getting notifications every 2 minutes. I also disabled groups.
Below is a screenshot of the alert’s evaluation time
I don’t know if this is relevant but I’m getting the following error in my contact point even though Teams receives notifications.
This is in version 10.4.2
Show your alert state history and your ms team notifications, Grafana debug logs, pls (formateed pls).
Here is a screenshot of the state history and teams. The status hasn’t changed since yesterday at 17:27 which is the last time I triggered the alert.
Please advise how to send the log. I have a file with 10 minutes worth of logs. Also, what is a good way to format? The best I could figure was to replace spaces with newlines. I think it’s more readable but looks odd.
Below are the logs which I thought could be relevant. Let me know if there is something missing
logger=tsdb.prometheus
endpoint=queryData
pluginId=prometheus
dsName=prometheus
dsUID=fdtfydy0bhl34f
uname=grafana_scheduler
rule_uid=edyspulkwxmgwc
org_id=1
t=2024-10-11T12:40:02.227357874Z
level=debug
msg="Sending
query"
start=2024-10-11T11:40:00Z
end=2024-10-11T12:40:00Z
step=15s
query="nifi_amount_items_queued
	{component_type=\"Connection\",
	destination_name=\"TFMS_UpdateCounter_acySolaceCounter_T1_P\",
	job=\"nifi\",
	source_name=\"TFMS_ConsumeJMS_NEMS-ACY-Solace_T1_P\"}"
logger=expr
	org_id=1
	datasourceType=prometheus
	queryRefId=A
	datasourceUid=fdtfydy0bhl34f
	datasourceVersion=2
	t=2024-10-11T12:40:02.229094665Z
	level=debug
	msg="Handling SSE data source query through dataplane"
	datatype=timeseries-multi
logger=expr
	org_id=1
	queryRefId=A
	datasourceVersion=2
	t=2024-10-11T12:40:02.229194654Z
	level=debug
	msg="Data source queried"
	responseType=dataplane-timeseries-multi
logger=secrets.kvstore
	t=2024-10-11T12:40:02.229257996Z
	level=debug
	msg="got secret value from cache"
	orgId=1
	type=datasource
	namespace=prometheus
endpoint=queryData
pluginId=prometheus
dsName=prometheus
org_id=1
t=2024-10-11T12:40:02.229380319Z
level=debug
msg="Sending
query"
step=15s
query="nifi_backpressure_object_threshold
	job=\"nifi\",
logger=expr
	org_id=1
	queryRefId=B
	datasourceVersion=2
	t=2024-10-11T12:40:02.230751544Z
	level=debug
logger=expr
	org_id=1
	queryRefId=B
	datasourceVersion=2
	t=2024-10-11T12:40:02.230834542Z
	level=debug
	t=2024-10-11T12:40:02.230879805Z
	level=debug
	orgId=1
	type=datasource
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:02.2309948Z
	level=debug
	msg="Sending query"
	step=15s
	query="nifi_amount_items_queued{component_type=\"Connection\",destination_name=\"TFMS_UpdateCounter_oexSolaceCounter_T1_P\",job=\"nifi\",source_name=\"TFMS_
	ConsumeJMS_
	NEMS-OEX-Solace_T1_P\"}"
logger=expr
	org_id=1
	queryRefId=C
	datasourceVersion=2
	t=2024-10-11T12:40:02.232176817Z
	level=debug
logger=expr
	org_id=1
	queryRefId=C
	datasourceVersion=2
	t=2024-10-11T12:40:02.232263457Z
	level=debug
	t=2024-10-11T12:40:02.232314218Z
	level=debug
	orgId=1
	type=datasource
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:02.232457131Z
	level=debug
	msg="Sending query"
	step=15s
	query="nifi_backpressure_object_threshold{component_type=\"Connection\",destination_name=\"TFMS_UpdateCounter_oexSolaceCounter_T1_P\",job=\"nifi\",source_name=\"TFMS_
	ConsumeJMS_
logger=expr
	org_id=1
	queryRefId=D
	datasourceVersion=2
	t=2024-10-11T12:40:02.233902006Z
	level=debug
logger=expr
	org_id=1
	queryRefId=D
	datasourceVersion=2
	t=2024-10-11T12:40:02.233994046Z
	level=debug
logger=ngalert.scheduler
org_id=1
version=149
fingerprint=59c2d878c1a155fe
attempt=1
now=2024-10-11T12:40:00Z
org_id=1
t=2024-10-11T12:40:02.234230187Z
level=debug
msg="Alert rule evaluated"
results="[{Instance:
	State:Alerting
	Error:<nil>
	Results:map[]
	Values:map[ACY Solace queued flowfiles:{Var:ACY Solace queued flowfiles
	Labels:__name__=nifi_amount_items_queued,
	component_id=bdf7406a-c3cd-1910-b74a-903fd1802140,
	component_name=success,
	component_type=Connection,
	destination_id=bdf7406e-c3cd-1910-b3f5-b5c85c0fbc89,
	destination_name=TFMS_UpdateCounter_acySolaceCounter_T1_P,
	exported_instance=https://172.26.21.73:8443/nifi,
	instance=172.26.21.73:28444,
	job=nifi,
	parent_id=a5ee5eaa-305d-3ade-fc86-b7510f49de18,
	source_id=bdf74067-c3cd-1910-e4d0-0cff4f72dbc6,
	source_name=TFMS_
	ConsumeJMS_
	Value:0xc000014ce0}
	ACY backpressure threshold:{Var:ACY backpressure threshold
	Labels:__name__=nifi_backpressure_object_threshold,
	job=nifi,
	source_name=TFMS_
	ConsumeJMS_
	Value:0xc00437ff80}
	OEX Solace queued flowfiles:{Var:OEX Solace queued flowfiles
	component_id=bdf7406c-c3cd-1910-1552-5be854b97393,
	destination_id=bdf74070-c3cd-1910-cea9-4548fb3d4b2a,
	destination_name=TFMS_UpdateCounter_oexSolaceCounter_T1_P,
	job=nifi,
	source_id=bdf74069-c3cd-1910-d849-580afdf101e9,
	source_name=TFMS_
	ConsumeJMS_
	Value:0xc00296b260}
	OEX backpressure threshold:{Var:OEX backpressure threshold
	job=nifi,
	source_name=TFMS_
	ConsumeJMS_
	Value:0xc00457e378}
	acyCondition:{Var:acyCondition
	Labels:
	Value:0xc00457e3c8}
	alert:{Var:alert
	Labels:
	Value:0xc00457e458}
	oexCondition:{Var:oexCondition
	Labels:
	Value:0xc00457e418}]
	EvaluatedAt:2024-10-11 12:40:00 +0000 UTC
	EvaluationDuration:2.234186372s
	EvaluationString:[
	var='ACY Solace queued flowfiles'
	labels={__name__=nifi_amount_items_queued,
	job=nifi,
	source_name=TFMS_
	ConsumeJMS_
	NEMS-ACY-Solace_T1_P}
	value=100
	var='ACY backpressure threshold'
	labels={__name__=nifi_backpressure_object_threshold,
	job=nifi,
	source_name=TFMS_
	ConsumeJMS_
	value=100
	var='OEX Solace queued flowfiles'
	job=nifi,
	source_name=TFMS_
	ConsumeJMS_
	NEMS-OEX-Solace_T1_P}
	value=0
	var='OEX backpressure threshold'
	job=nifi,
	source_name=TFMS_
	ConsumeJMS_
	value=100000
	var='acyCondition'
	labels={}
	value=1
	var='alert'
	labels={}
	value=1
	var='oexCondition'
	labels={}
	value=0
	duration=7.822122ms
logger=ngalert.state.manager
	org_id=1
	t=2024-10-11T12:40:02.234372921Z
	level=debug
	msg="State manager processing evaluation results"
	resultCount=1
	org_id=1
	instance=
	t=2024-10-11T12:40:02.234620326Z
	level=debug
	msg="Setting next state"
	handler=resultAlerting
	org_id=1
	instance=
	t=2024-10-11T12:40:02.234665014Z
	level=debug
	msg="Keeping state"
	state=Alerting
	previous_ends_at=2024-10-11T12:41:40Z
	next_ends_at=2024-10-11T12:42:00Z
logger=ngalert.image
	org_id=1
	dashboard=cdxt4i23o5on4d
	panel=2
	t=2024-10-11T12:40:02.234713444Z
	level=debug
	msg="Requesting
	screenshot"
logger=ngalert.state.manager.persist
	t=2024-10-11T12:40:02.234753733Z
	level=debug
	msg="Saving alert states"
	count=1
	max_state_save_concurrency=1
	t=2024-10-11T12:40:02.239780301Z
	level=debug
	msg="Saving alert states done"
	count=1
	duration=5.023905ms
	t=2024-10-11T12:40:03.338683343Z
	level=debug
	orgId=1
	type=datasource
6084
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:23.340817437Z
	level=debug
	msg="Sending query"
	start=2024-10-11T11:40:20Z
	end=2024-10-11T12:40:20Z
	step=15s
	query="nifi_amount_items_queued{component_type=\"Connection\",destination_name=\"TFMS_UpdateCounter_acySolaceCounter_T1_P\",job=\"nifi\",source_name=\"TFMS_ ConsumeJMS_ NEMS-ACY-Solace_T1_P\"}"
logger=expr
	org_id=1
	queryRefId=A
	datasourceVersion=2
	t=2024-10-11T12:40:23.342332193Z
	level=debug
logger=expr
	org_id=1
	queryRefId=A
	datasourceVersion=2
	t=2024-10-11T12:40:23.342438058Z
	level=debug
	t=2024-10-11T12:40:23.342492059Z
	level=debug
	orgId=1
	type=datasource
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:23.342617924Z
	level=debug
	msg="Sending query"
	step=15s
query="nifi_backpressure_object_threshold{component_type=\"Connection\",destination_name=\"TFMS_UpdateCounter_acySolaceCounter_T1_P\",job=\"nifi\",source_name=\"TFMS_ConsumeJMS_NEMS-ACY-Solace_T1_P\"}"
logger=expr
	org_id=1
	queryRefId=B
	datasourceVersion=2
	t=2024-10-11T12:40:23.34378241Z
	level=debug
logger=expr
	org_id=1
	queryRefId=B
	datasourceVersion=2
	t=2024-10-11T12:40:23.3438768Z
	level=debug
	t=2024-10-11T12:40:23.343923789Z
	level=debug
	orgId=1
	type=datasource
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:23.344040967Z
	level=debug
	msg="Sending query"
	step=15s
	query="nifi_amount_items_queued{component_type=\"Connection\",destination_name=\"TFMS_UpdateCounter_oexSolaceCounter_T1_P\",job=\"nifi\",source_name=\"TFMS_ ConsumeJMS_ NEMS-OEX-Solace_T1_P\"}"
logger=expr
	org_id=1
	queryRefId=C
	datasourceVersion=2
	t=2024-10-11T12:40:23.345281284Z
	level=debug
logger=expr
	org_id=1
	queryRefId=C
	datasourceVersion=2
	t=2024-10-11T12:40:23.345363099Z
	level=debug
	t=2024-10-11T12:40:23.345410784Z
	level=debug
	orgId=1
	type=datasource
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:23.345531795Z
	level=debug
	msg="Sending query"
	step=15s
	query="nifi_backpressure_object_threshold{component_type=\"Connection\",destination_name=\"TFMS_UpdateCounter_oexSolaceCounter_T1_P\",job=\"nifi\",source_name=\"TFMS_ ConsumeJMS_ NEMS-OEX-Solace_T1_P\"}"
logger=expr
	org_id=1
	queryRefId=D
	datasourceVersion=2
	t=2024-10-11T12:40:23.346822699Z
	level=debug
logger=expr
	org_id=1
	queryRefId=D
	datasourceVersion=2
	t=2024-10-11T12:40:23.346911627Z
	level=debug
	org_id=1
	version=149
	attempt=1
	now=2024-10-11T12:40:20Z
	org_id=1
	t=2024-10-11T12:40:23.347139413Z
	level=debug
	State:Alerting
	Error:<nil>
	Results:map[]
	job=nifi,
	source_name=TFMS_ ConsumeJMS_ NEMS-ACY-Solace_T1_P
	Value:0xc00459b560}
	job=nifi,
	Value:0xc004377240}
	job=nifi,
	source_name=TFMS_ ConsumeJMS_ NEMS-OEX-Solace_T1_P
	Value:0xc002db9b80}
	job=nifi,
	Value:0xc0044335b8}
	Labels:
	Value:0xc004433608}
	alert:{Var:alert
	Labels:
	Value:0xc004433698}
	Labels:
	Value:0xc004433658}]
	12:40:20 +0000 UTC
	EvaluationDuration:3.347095645s
	EvaluationString:[
	job=nifi,
	source_name=TFMS_ ConsumeJMS_ NEMS-ACY-Solace_T1_P}
	value=100
	job=nifi,
	value=100
	job=nifi,
	source_name=TFMS_ ConsumeJMS_ NEMS-OEX-Solace_T1_P}
	value=0
	job=nifi,
	value=100000
	var='acyCondition'
	labels={}
	value=1
	var='alert'
	labels={}
	value=1
	var='oexCondition'
	labels={}
	value=0
	duration=7.33754ms
	org_id=1
	t=2024-10-11T12:40:23.347288581Z
	level=debug
	resultCount=1
	org_id=1
	instance=
	t=2024-10-11T12:40:23.347546789Z
	level=debug
	org_id=1
	instance=
	t=2024-10-11T12:40:23.347592119Z
	level=debug
	msg="Keeping state"
	state=Alerting
	previous_ends_at=2024-10-11T12:42:00Z
	next_ends_at=2024-10-11T12:42:20Z
	org_id=1
	panel=2
	t=2024-10-11T12:40:23.347626117Z
	level=debug
	msg="Requesting
	screenshot"
	t=2024-10-11T12:40:23.347664708Z
	level=debug
	count=1
	t=2024-10-11T12:40:23.366468095Z
	level=debug
	count=1
	duration=18.800583ms
logger=ngalert.sender.router
	org_id=1
	t=2024-10-11T12:40:23.366558046Z
	level=info
	msg="Sending alerts to local notifier"
	count=1
logger=ngalert.notifier.alertmanager
	org=1
	t=2024-10-11T12:40:23.366597388Z
	level=debug
	component=alertmanager
	orgID=1
	msg="Putting alert"
	alert="Solace reaching or reached backpressure threshold[8f31d10][active]"
	starts_at=2024-10-10T21:27:20Z
	org=1
	t=2024-10-11T12:40:23.366660722Z
	level=debug
	orgID=1
	component=dispatcher
	msg="Received alert"
	t=2024-10-11T12:40:24.451718451Z
	level=debug
	orgId=1
	type=datasource
12864
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:47.780509407Z
	level=debug
	msg="Sending query"
	start=2024-10-11T11:40:40Z
	end=2024-10-11T12:40:40Z
	step=15s
logger=expr
	org_id=1
	queryRefId=A
	datasourceVersion=2
	t=2024-10-11T12:40:47.78292463Z
	level=debug
logger=expr
	org_id=1
	queryRefId=A
	datasourceVersion=2
	t=2024-10-11T12:40:47.783022247Z
	level=debug
	t=2024-10-11T12:40:47.783071035Z
	level=debug
	orgId=1
	type=datasource
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:47.783188426Z
	level=debug
	msg="Sending query"
	step=15s
	query="nifi_backpressure_object_threshold{component_type=\"Connection\",destination_name=\"TFMS_UpdateCounter_acySolaceCounter_T1_P\",job=\"nifi\",source_name=\"TFMS_ ConsumeJMS_ NEMS-ACY-Solace_T1_P\"}"
logger=expr
	org_id=1
	queryRefId=B
	datasourceVersion=2
	t=2024-10-11T12:40:47.785281938Z
	level=debug
logger=expr
	org_id=1
	queryRefId=B
	datasourceVersion=2
	t=2024-10-11T12:40:47.78536964Z
	level=debug
	t=2024-10-11T12:40:47.785416616Z
	level=debug
	orgId=1
	type=datasource
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:47.785536218Z
	level=debug
	msg="Sending query"
	step=15s
logger=expr
	org_id=1
	queryRefId=C
	datasourceVersion=2
	t=2024-10-11T12:40:47.787521358Z
	level=debug
logger=expr
	org_id=1
	queryRefId=C
	datasourceVersion=2
	t=2024-10-11T12:40:47.787688331Z
	level=debug
	t=2024-10-11T12:40:47.787797432Z
	level=debug
	orgId=1
	type=datasource
	endpoint=queryData
	pluginId=prometheus
	dsName=prometheus
	org_id=1
	t=2024-10-11T12:40:47.787990934Z
	level=debug
	msg="Sending query"
	step=15s
logger=expr
	org_id=1
	queryRefId=D
	datasourceVersion=2
	t=2024-10-11T12:40:47.790177304Z
	level=debug
logger=expr
	org_id=1
	queryRefId=D
	datasourceVersion=2
	t=2024-10-11T12:40:47.790280073Z
	level=debug
	org_id=1
	version=149
	attempt=1
	now=2024-10-11T12:40:40Z
	org_id=1
	t=2024-10-11T12:40:47.790570492Z
	level=debug
	State:Alerting
	Error:<nil>
	Results:map[]
	job=nifi,
	Value:0xc00458e2b0}
	job=nifi,
	Value:0xc002b6a780}
	job=nifi,
	Value:0xc003dbb7d0}
	job=nifi,
	Value:0xc0044afa98}
	Labels:
	Value:0xc0044afae8}
	alert:{Var:alert
	Labels:
	Value:0xc0044afb78}
	Labels:
	Value:0xc0044afb38}]
	EvaluatedAt:2024-10-11 12:40:40	+0000	UTC
	EvaluationDuration:7.790511873s
	EvaluationString:[
	job=nifi,
	value=100
	job=nifi,
	value=100
	job=nifi,
	value=0
	job=nifi,
	value=100000
	var='acyCondition'
	labels={}
	value=1
	var='alert'
	labels={}
	value=1
	var='oexCondition'
	labels={}
	value=0
	duration=11.145739ms
	org_id=1
	t=2024-10-11T12:40:47.790747624Z
	level=debug
	resultCount=1
	org_id=1
	instance=
	t=2024-10-11T12:40:47.791073601Z
	level=debug
	org_id=1
	instance=
	t=2024-10-11T12:40:47.791118337Z
	level=debug
	msg="Keeping state"
	state=Alerting
	previous_ends_at=2024-10-11T12:42:20Z
	next_ends_at=2024-10-11T12:42:40Z
	org_id=1
	panel=2
	t=2024-10-11T12:40:47.791172701Z
	level=debug
	msg="Requesting
	screenshot"
	t=2024-10-11T12:40:47.791229333Z
	level=debug
	count=1
	t=2024-10-11T12:40:47.806882121Z
	level=debug
	count=1
	duration=15.651479ms
	t=2024-10-11T12:40:48.891954891Z
	level=debug
	orgId=1
	type=datasource
Hey, did you end up fixing this? I got exactly the same issue
I didn’t end up fixing this. We were going to revisit this, but I no longer work there.
