Alerts Colors in the Charts: from Green/Red to Blue? why?
    8.1.1, in Azure APP Service, by using AZURE API datasource to read data from Events HUBS
    I want to show starts-end of the alerts on any chart with color red and green. CUrrently are always blue.
    Asking your support!!!
  • What happened?
    In version < 8.x my current alerts where appearing on the chart with RED and GREEN colors (RED Start - GREEN solved). Now they always appear as light BLUE dotted lines. I can i restore the previous setup?
    My current alerts are all set up as “Evaluate for 1min every 0min” in order to catch specific punctual events in the last 5 min bucket. As I said before this was generating Green/Red colors which now changed in BLUE.
    It occurred after update to version 8.x.x
Hello I’m currently facing the exact same problem than @dsalvigni
All alerts appear in blue without any text. I try to add test and tags in the alert rules but when I request the annotations created via the API they don’t contain the text or the tags defined in the alert rule.
Was working fine before migration to version 8
Hello COmmunity…any suggestion, or workaround?
Thank you!!
Hello Community…nothing really???
