Alerting default configuration not taken into account
Hi there,
I need help with two configurations on alerts. I can’t tell if this is a misunderstanding on my part or a possible bug.
    Grafana v9.2.4
    I want to change the default configuration defined in grafana.ini for [Alerting] error_or_timeout and [Alerting] nodata_or_nullvalues
    Change the value inside grafana.ini, then restart grafana.
  • What happened?
    Modifying values in the grafana.ini file is not taken into account.
    Unless I am mistaken, the values should be taken into account when creating a new alert by automatically setting the default values on this step.
    But whatever the value defined in the grafana.ini, this value remains
  • “No Data” for nodata_or_nullvalues
  • “Error” for error_or_timeout
    It is indeed possible to make the modification manually during this step, but the default configuration does not seem to be taken into account.
    No error displayed.
Moreover, it seems that there is a difference between the docs and the front.
nodata_or_nullvalues :
  • Docs : Options are alerting , no_data , keep_state , and ok . Default is no_data
  • Front : Options are alerting , no_data , and ok . Default is no_data
error_or_timeout :
  • Docs : Options are alerting ,keep_state . Default is alerting
  • Front : Options are alerting , error , and ok . Default is error
Grafana Docs source : Configure Grafana | Grafana documentation
Thank you in advance for your help !
Hi @rmacgi and welcome to the :grafana: Grafana Community forum!
Assumming you have uncommented each line of the grafana.ini, could you please copy paste the values for error_or_timeout, and nodata_or_nullvalues as they are in your current grafana.ini, or provide a screenshot ?
Hi @antonio.merello and thank you for your response.
I do not use the grafana.ini file directly because I am in a docker environment (Azure App service).
In my case I use configuration override with environment variables.
Azure App settings
Grafana settings (after override)
Other configurations use this method and are well taken into account.
Hi again @rmacgi and thanks for the info
We have managed to reproduce your scenario in a docker environment resulting in a similar behavior. This might be a valid issue. If so, we would also address the mismatch between the options for alerting in docs, .ini, and GUI
I will go ahead an report the issue to our Github repository Once it is open, I will share the link here.
Thank you
Thank you for your help @antonio.merello !
you are welcome @rmacgi !
here is the link to the issue on github
Hi! It looks like you are changing configuration for legacy alerting but the screenshot shows you using unified alerting. If you would like to change configuration for unified alerting then you can do so under [unified_alerting] instead of [alerting].
Hi @georgerobinson
I’m not sure to understand your answer. These two configurations do not exist in the [unified_alerting] section. Does this mean that changing the default settings for creating an alert is no longer possible since V9?
I don’t see the link between unified alerts and the default configurations of an alert when it is created.
Hi! I don’t think the default values for Error and No Data are configurable in the ini file when using Unified Alerting I’m afraid.
