Alert tab does not appear for me in Grafana 6.3.5
Dear community,
I have an issue with Grafana, Alert tab does not appear for me :slight_smile:
I have admin rights and alerting is enable in grafana.ini file
did any one have an idea about the problem here ?
Thanks in advance,
Regards,
Otmane,
Configure Alerting | Grafana documentation :
Currently only the graph panel supports alert rules but this will be added to the Singlestat and Table panels as well in a future release.
Did you use supported panel type?
ok Thanks for the info
Seems there is still no support for alert rules with Singlestat panels. Is that correct? I just want to be sure. Thanks.
