Akenza Plugin: Installation possible?
Hello to the community
Is it possible, to install this Plugin
into the Grafana cloud? If yes, can someone do this for me (of course, for a fee).
Thanks a lot
Markus
Unfortunately this is not possible on Grafana Cloud. Unsigned plugins are not supported in Grafana Cloud → the akenza-io/grafana-connector-v3 is not in the official Grafana plugin catalog, so it cannot be installed regardless of who does it or what fee is paid.
Your options
Self-hosted Grafana → run Grafana yourself on a VPS, server, or Docker where you control the configuration and can load the plugin manually.
Grafana Data Source Plugin | akenza.io
Use akenza’s own hosted Grafana → akenza offers their own Grafana installation with the plugin already pre-installed. No self-hosting needed. Contact them at: akenza | About us
Ask akenza to support Grafana Cloud → they previously chose not to publish to the official Grafana catalog. You can request it at: Issues · akenza-io/grafana-connector-v3 · GitHub
Hello Infofcc3
Thanks for the reply.
Oh, this is very sad :frowning:
I saw Sliplane - and made a testaccount. Grafana works.
What dou you think: Is it possible there?
Best regards
Markus
