AJAX POST request body
    Running in Docker:
    bash-5.0$ ./bin/grafana-server -v
    Version 7.5.7 (commit: 91de51771c, branch: HEAD)
    Make a REST POST call out to my own (SpringBoot) API
    Using the AJAX panel plugin
    AJAX plugin for Grafana | Grafana Labs
Where body and headers are filled in.
  • What happened?
    It seems to be hitting the end-point but error occurs complaining about missing body.
    Get a response/POST successful
    See picture.
    Response error in panel:
error: "Bad Request" message: "Required request body is missing: public org.springframework.
But nothing in grafana.log
    There is very little relating to POST for AJAX panel with a JSON body.
Turns out POST not supported with body.
Seems the plugin is not being maintained, see reply from Grafana support.
Indeed, it looks like POST JSON data to backend is not currently supported. There seem to be two related issues here:
You’re welcome to share your thoughts there, it looks like this feature request has been added as a future enhancement but I am not sure when that work will be completed. In the meantime, you may need to forego using the AJAX Plugin.
hi @egarcol,
I highly recommend you try out the JSON API plugin for Grafana | Grafana Labs by Marcus Olsson. It’s actively maintained and very good.
I’m using it to make POST requests with a body to an API service.
