Grafana API post error
I am trying to create a dashboard in Grafana through an AJAX post method, hoping to create a dashboard through my website post, but I dont know why I always got console.log(“Client POST Error”);.( fixed - see my comment)
I am using Node.js as my web server.
But I encounter another problem is “Response to preflight request doesn’t pass access control check: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.”
Should I reconstruct from
website -> grafana
to
website -> webserver(reverse proxyserver) -> grafana?
Is that will be a better way?
This is my JavaScript code:
var dashboard = {
    "dashboard": {
        "id": null,
        "title": "WebPos",
        "tags": [ "templated" ],
        "timezone": "browser",
        "rows": [
        "schemaVersion": 6,
        "version": 0
    "overwrite": false
$(document).ready(function(){
    $('#post').click(function(){
        console.log("Client Clicked");
        $.ajax({
            url: 'http://10.3.1.25:3000/api/dashboard/db',
            type:'post',
            dataType:'json',
            data:JSON.stringify(dashboard),
            success: function(data){
                console.log("Client POST Success");
            error: function(e){
                console.log("Client POST Error");
                console.log(e);
            beforeSend: setHeader
function setHeader(xhr) {
    xhr.setRequestHeader('Authorization', 'Bearer eyJrIjoiVGJyWTJuS2dyNVV0VG93Z3FqR0IIQ1hYblJVUlpBTEQiLCJuIjoiZWRpIiwiaWQiOjF9');
    xhr.setRequestHeader('Access-Control-Allow-Headers:*');
If you’re calling grafana from a browser website and the grafana and website runs on different domains you’ll probably need to setup a proxy with support for CORS negotiation.
@anon34853223 buhhhaa wrong…
Any idea what Proxy is? What CORS is? NO
So I’d suggest you learn first
