What Grafana version and what operating system are you using? : v8.3.4
What are you trying to achieve? : Need to do field override, i.e. to replace some IDs coming in legend into meaningful names. I have key value list for the same.
How are you trying to achieve it? : There should be some way to bulk upload all the key-values using file/csv import or some bulk API
What happened? Not able to find any.,
